John Smith
- Jan 17, 2010
- Reaction score
- 6
I used to own and "operate"
some diesels that would run w/o any electrics involved...but if ur gonna go that route better be prepared to operate w/o modern computerized diesel technology...it's do-able but would take planning...choose your engines well and do your research about how they run...
and yes..they can run w/o "any" electrical influence if you have your ducks in line...but i wouldn't do it unless you had a fuel supply in mind...tween you and your friends..but definitely do-able...but it's a one trick pony..no diesel..no go...albeit it may run for a while with "less than usable fuel"..add a little atf if you do..and/or/a little used motor oil..
I think diesel is better, especially a simple mechanical injected diesel. While diesel fuel is not as common at inner city gas stations, if you're bugging out, you're sure to cross by many truck stops, farmers, and crops that could be turned into fuel just as easily as distilling to make ethanol.
