bronco II frame question
scotiascrapiron
Hampton S.C.
302 soon to be 393
I just installed a 302 into my bronco II and the exhaust manifold on the passenger side came down about half way across the frame and i'm not going to be able to bolt the exhaust pipe up to the manifold.How much of the top of the frame rail can I cut out,if any, and not have to worry about hittin the dirt the first time I hit a hole? Any other ideas about what to do to fix this would be welcome.These are stock manifolds from a 78 LTD.It was my donor car.
projectnitemare
8
Osceola Mills, Pa
396W
The best suggestion will be do go to the junkyard and find a better fitting manifold, they are out there. You can cut the frame if you wish, I wouldn't go back more than 3/4in or so. I saw a local kid here who pretty much cut out the top of the frame rail to clear headers on a V8 Ranger. I only saw that around for one summer.
Matt
scotiascrapiron
Hampton S.C.
302 soon to be 393
thanks for the info nightmare. I got to make a junkyard run anyway. The local yard has some 8.8s i need to look into and will see about the manifolds while i'm there.
88mudder
waterford michigan
you can notch out the frame. Dont go overboard. Cut out just enough to clear the exhaust flange. It shouldnt be too much to cut, anyways.
rangerslim
July OTOTM Winner
302 v8
I am going thru the exact same thing......Whoever said the mustang tri-y's fit are full of sh**.....I am going to cut about 4 inches out of the passenger side header today at work and will have to bend the drivers side over to clear the front driveshaft......
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
They fit on 2wds...
rangerslim
July OTOTM Winner
302 v8
I have just massacred the passenger side of that tri-y.....hope it fits....
mhughes165
9
302
i have before actually cut all the way to the vertical part of the fram, however i did reinforce it in that area on the under side and box it back in on top so it cleared the headers i used just fine
mudnsnow
Matane QC CA
5.0L EFI
Go on ebay and try to find one of these
D5DE-9430-BC
B24FREE
Peoria?Bartonville IL.
FORD
I am using stock cast iron manifolds from a 2000ish explorer. With Advance Adapters adapter plates and the suggested common OEM ford rubber mounts the drivers side fits great and the passanger side flanve clears the top of the frame by 1/4" - 1/2" depending how far foward you have the motor.
http://www.1aauto.com/1A/ExhaustManifolds/Ford/Explorer/1AEEM00198/44728
http://images.google.com/imgres?imgurl=http://thumbs.1aauto.com/EEK/1AEEK00069.jpg&imgrefurl=http://www.1aauto.com/1A/ExhaustManifolds/Ford/Explorer&h=75&w=75&sz=3&hl=en&start=12&um=1&tbnid=eVL7le33z_uhyM:&tbnh=71&tbnw=71&prev=/images?q=explorer+exhaust+manifold&um=1&hl=en&safe=off&sa=G
wade
Norfolk, VA
5.0L
Same, here! But I'm welding angle iron onto the outside top of the frame to recover some of the lost rigidity.
