Brake Booster ????
budro
I have a 92 Ranger 4x4 Super Cab 4.0 V6. Have a weird problem with the brake pedal. Bleeding it with the engine off on all 4 wheels gives me a rock hard pedal. Start it up and the pedal same as goes to the floor to stop. I replaced the back brake shoes cause some of the hardware was broken when i was troubleshooting this problem. So new brakes on back the pads on front are better than 50%. I get a swoosh sound just when i push the pedal not a continous vacuum sound when i hold the pedal down. I have had boosters go bad before but they usually make a continous vacuum leak as you keep it held down and usually the pedal gets hard to push. It never bleeds down to where i have to pump it once to hold, to make me think its a master cylinder Anyone else run into a similar problem?
budro
Forgot to mention new wheel cylinders were installed in the rear as well.
cocoasranger
5
south central Pa.
Did you replace the brake master cylinder? If so, check the booster adjustable rod for proper length; if too short the pedal will go way down before stopping.
budro
Nope havent replaced it as it holds pressure. The pedal never goes to the floor or bleeds of like symptoms of a master cylinder.
Thinking possibly the RABS Valve???
budro
Found Problem
Found out what was going on finally after staring at the rear brakes for a while comparing pics to the manual. The previous owner had put the shoes on backwards. They had the fronts on the back side and back on front. Just assumed they were right and put the new ones on the same way. The adjusters would never adjust up right. Flipped them back the right way and boom instant hard pedal with the engine running. Just FYI for anyone else if you are having any similar problems.
