bolt pattern conversion
QuakerShaker4242
Avon, IN
4.0l V6
hey guys im in this situation. i have a waggy dana 44. its bolt pattern is 6x5.5. i was wondering what i would have to do to make it match the back which is 5x4.5. i havent seen anything and i dont want to use spacers...
i just wanted to do this so i could keep the same wheels i have now.
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
some 70s dodge D44 front ends had 5*4.5 lug pattern. the bolt pattern issue is one reason that alot of people chose to use early bronco axles or D30s instead of waggy 44s.
c_note
September 2009 OTOM Winner
back in San Diego, CA
Ranger/Explorer
4.0 sohc
have a machine shop drill you out a 5 on 4.5 bolt hole circle and put in the new studs and ur set.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
i dont think that the d44 hubs will fit through the hole on a 5*4.5 wheel. also grinding them out wont work cause there wont be enough material left near the bolt holes for it to be safe enough to drive.
Toreadorranger
5
Sal
EB axles are 5x5.5 not 5x4.5 like a ranger.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Most guys swap to 5x5.5 in the front and then run a spacer/adapter on the rear, otherwise you are pretty much out of luck
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
If you absolutely MUST keep 5x4.5" on a D44, then the Dodge stuff is your only option (or maybe TJ Rubicon stuff might fit, although it's weaker than the Dodge). The Dodges had quite a few issues with the wheelbearings though.
I'd do as suggested above, get new wheels and run adapters on the rear (or redrill the flanges) to match the existing lug pattern on the D44.
dude772
Caledonia, Ontario
5.0L
Ive got aftermarket aluminum wheels on my explorer that have a centre hole big enough to fit over the hub of a dana44 and has the 4.5 bolt circle. They also use shank stlye lug nuts. And theres more than enough material there to be safe.
Toreadorranger
5
Sal
Rubicon Stuff wont fit as the Rubicon axle is a D44 center section with Dana 30 outers.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The knuckles (Cs) are D30 too? Scratch that one then (wasn't sure).
QuakerShaker4242
Avon, IN
4.0l V6
ok so its clear that unless i drill that i cant get the front to 5x4.5
so is it possible to get the back to 6x5.5??
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
redrill if the flanges are large enough, custom axle shafts, or wheel adaptors which i dont recommend because they have been known to break.
Toreadorranger
5
Sal
New shafts are your best bet. 034x4 (jey) from RF had new shafts made for his 8.8 for this exact reason.
Natedog57
Central Florida
I also got some shafts made by Dutchman MS, great company to work with. Same as the Ex shafts except the 6x5.5 pattern, also took the rotors to a machineist. Works great.
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
why not swap in chevy or yota axles in the rear?
IIRC Taco axles use a 6x5.5 lug pattern
And the semi float 14bolts use a 6x5.5 pattern
