- Aug 19, 2007
- 125
- Age
- 35
- Everett, WA
- Ford
- Engine Size
- 3.5 Eco
All 6 lugs are 6x5.5
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The newer 6 lug f150's are a metric bolt paternAll 6 lugs are 6x5.5
specifically?The newer 6 lug f150's are a metric bolt patern
04 and up 6 lug f150's are 6x135mmspecifically?
why not swap in chevy or yota axles in the rear?
IIRC Taco axles use a 6x5.5 lug pattern
And the semi float 14bolts use a 6x5.5 pattern
yea im going to be running 38s...the best solution to this problem would seem to be a D30 then. bolt pattern would match. width would match.
idk how big your going on the tires but more than 35s would be getting dangerous even if its only a 2wd with that axle.
i live in plainfield indianawhere are you located? if your close enough, i can machine them for you.
