Ball Joint Knuckle Removal Help
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I am replacing ball joints on my 94 4wd. I am down to bare knuckles that need removed from the axle. Does the alignment bushings need removed to remove the knuckle? If so, how do I get them out? If not how do I get the knickle out? Thanks!
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Just loosen off the pinch bolt that holds the upper balljoint in there. Take a hammer and beat on the knuckle at the balljoint, it'll pop out. Since you are changing the balljoints you could also use a pickle for to pop them apart. The alignment bushing doesn't need to come out.
wizkid00104
13
2.3L/5.4L
One more question, one of my wheel bearings was destroyed when I took the disc off. I got the new bearing. The only problem is that I can not get the old racetrack out of the rotor. Any ideas?
MAranger
Ipswich, MA
245c.i.
Heat and a bigger hammer
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
If you have a welder you can run a bead of weld around the inside of the race and it should fall right out.
