OK, small update.
We have been quite busy lately... people love carbon fiber, but i had a few seconds to work on the truck. Iv been wanting to taper the end of my bed sides. Here is what i did, so some of you that may want to cut there beds know what there looking at.
First i taped up how i wanted to cut my bed. The tape is an excellent guide for a straight line and wont let the paint chip off when you use your cutting wheel.
Next i cut the supports on the inside of the bed, so when i made my cut on the exterior of the bed so it would fall right off.
Then i took a flat bar i had laying around clamped it to the bed. I clamped it at the same angle as my desired line i want to cut. This will insured that no "mishaps" would happen and id have a perfect cut. I didnt take a pic of this step on the left side so i took a pic of when i did it on the right side. You get the idea.
So i cut the section off of the bed. You will notice the inner support still attached.
All done. I cut the support out. I then took my DA sander and cleaned up the sharp edges. Then took some clear coat and sprayed just the edges to make sure it wouldn't rust up on me. I plan to paint the truck in the near future. I think it looks good. If i have time i will start my rear bumper this week. I also ordered my Derlin bushings, sleeves, spacers, and radius tabs to make the hinge for my tire gate im going to build.
So i was searching on RPS (RangerPowerSports) in the 2.3L engine tech area and found a pretty cool mod! Took 5min and works great. I was not aware, but the Ranger has a HUGE problem with the throttle cable stretching over time, so you never really notice the power loss. Basically the cable stretches out so you never have wide open throttle. My cable was stretch about 1 1/4"!!!! I did the mod to fix it and i figured i was loosing about 20-25% of throttle opening. What a HUGE difference! I knew the 2.3 was a dog... but man she has some skoot now....
Here is the link... If you havent done it... DO IT!!!
http://www.rangerpowersports.com/forum/showthread.php?t=159533
More soon
~Shawn
