B3000 Idle/throttle problem
klwilliam
Mazda
I have a 94 B3000 and it has been idling irregularly, and also as I'm driving down the road it will make different clicking noises, and then it acts as like my throttle is stuck. I will push in the clutch to switch gears and the motor will rev up to almost 4000rpms. Even while I'm driving I will let go of the gas and it acts if the throttle is stuck and it will maintain the speed. It will idle down if I slow down using the clutch to force the rpm's back down, but this is not good for my clutch, and quite embarrassing. I have noticed that if I unplug the idle air control valve it doesn't rev up, or act if the throttle is stuck. Then again it idles bad, and sometimes won't start if I don't have it plugged in. I'm thinking its either the idle control valve or possible the throttle position sensor. Any help on this issue would be much appreciated, thanks for your time.
bcost882
5
The Queens Country.....
3.0L, 1.6L
sounds like you need to replace the IAC and possibly the TPS. and while you are at it go ahead and clean the Maf
Research Rat
Mazda
I'm having the same issue on my 94 b3000 (search feature is a great thing!)
I know it's a post from a year ago, but I'm curious if you identified the culprit and solution? Is this a common issue?
-Scott
modelageek
14
Boston, MA
-Scott
start a new thread in the 3.0 engine forum...give as many details as you can...............for now start with cleaning the idle air control valve, the throttle body and the maf.....and check for codes.......all those are maintenance items anyways
