axle truss?
unoleisu
6
Stillwater, Okla
Ok. I'm about to do a 8.8 axle swap into my 87 BII. While I'm relocating perches and shock mounts, I thought about going ahead and doing trusses. I'm trying to decide weather to bother with it, or not. Is it going to be worth the trouble? Do I need them, will I gain anything?
Thanks. I doubt I'll be rock crawling, just occasional rougher offroad. Mostly DD.
Thank:icon_welder:s
Guilius
Millbury, MA
it never hurts, but the real question would be why?
when you do your 8.8 put a bead of weld around the tubes where they hit the diff housing. they are just pressed in and this will really help. go slow...do a small bit at a time and let it cool... do one side then the other.
but if you just want a truss because....... there's many to choose from.
here's a cool one.
http://www.undercoverfab.com/truss-systems/92-ucf-dana-44-rear-truss-system.html
and another from one of my favorite stores.
a truss wit tabs. you can leave the tabs off and just use the truss.
http://claytonoffroad.com/product_info.php/cPath/17_53/products_id/131
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
light offroading, i'd say no. an 8.8 is pretty darn strong. but you could do it anyway, just incase you wanted to do a doubler down the road. what size tires you running?
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
If your gonna swap it in, you might as well do it. Its not that much extra work. Speaking from experience, I have twisted a tube in a 8.8. Granted I do have a doubler, 35's and wheel some pretty crazy trails.
Here is a quick pic of mine... not the fanciest... but it works!
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Did you have your tubes welded to the chunk when it twisted?
59bisquik
Solid Axle Swap 4x4
Junkie...
Nope it was just a stock 97 Sploder housing. Now I weld the pumpkin and tubes in a few spots and added a truss for extra precaution.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
10-4.
Yeah the truss definitely doesn't hurt, though I also would say IMO that unless you plan to be jumping it (truss it along the bottom), or building a 4-link suspension (overhead truss like 59's or the ones Guilius posted links to), it's probably something not really needed. For sure do weld the tubes to the chunk though.
Spun tubes is a well-known issue with 8.8s used hard, they only have 3 small plug-welds holding them in.
cammeddrz
23
Ford/chevy
efi 350vortec
welding the tubes in your back yard can do little to no good at all. welding mild-steel tubes to a cast-iron housing requires the proper use of pre-heating in the right spots or else it just makes the weld (and the surrounding metal) more brittle than it even was to begin with. i wish i had a dollar for every mustang guy around here who just blasted a bead around his 8.8 tubes. just to tear the diff apart right there before even hitting the 60-foot line at the drag-strip
59bisquik
Solid Axle Swap 4x4
Actually, I used Protectic 4026N high nickel alloy rod to weld mine. Its expensive at about $25 dollars a pound and we use it at work on very large diesel engines with cast steel blocks. Only draw back is that it is very hard to find.
CHKNFKR
73
Illinois
545 CID
If you plan on abusing it truss it along the bottom. No matter how strong you think your truss is, the fact is it's far more likely to crumple on top than stretch on bottom. If the couple inches of lost clearance are a problem for you get taller meats.
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
the center will hold fine when welded, keep trying though.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
And it is cast steel, not iron.
unoleisu
6
Stillwater, Okla
Hmm, ok, those are some things to consider. I did plan to weld the tubes, and I think I will go ahead and build a truss. Ya never know when I may get adventurouse and need that extra support. I might go top AND bottom, but I haven't seen too many good examples of bottom trusses, mainly "smack plates" or whate ever the really thick gaurds are called.....
59bisquick, does that second pic show the forward support bolting on to the pinion housing?
unoleisu
6
Stillwater, Okla
My budget currently allows me to keep my 29" tires, but plan to run 31" or maybe 33" in the near future. I'm concentrating my resources on mechanical upgrades at the moment. After the 8.8 install, I'll be working on a D35 swap. Then the 4.0 swap.
I already replaced my A4LD with an '94 EXP M5OD. I have my BW1350 E still in the truck, but a BW1354 E sitting on a table, waiting for me to decide when to put it in. (I'd rather go manual, but haven't found one locally yet.) Anyway, going one step at a time. Trying to do it as right as I can, while I'm doing it the first time.
59bisquik
Solid Axle Swap 4x4
59bisquik, does that second pic show the forward support bolting on to the pinion housing?
Yes, I used the 3 bolt pattern next to the pinion to attach the truss.
Most dont truss underneath unless they plan on jumping it, also it limits your ground clearance. I rotated my shock mounts and everything else up so nothing is hanging down to get snagged.
