Axel shaft bearings?
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
I need to know because i have no experiance with axles, do i need to pack my axel shaft bearings with axel grease or does the gear oil lube them?
its a ford 9".
97BlackBetty
Norman, Ok
Gear lube does it all, althougb it is good practice when your putting new bearings in, to put some gear lube i em before you seal it back up. After all it doest take the lube sometime to make its way down the axle shafts.
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
so i shouldnt use axel grease?
kunar
131
Toledo, Ohio
5.8l
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
ok thanks and sorry ive been up 43 hours and all the letter look the same right now.
