any way to get 31/10.50/15's on 86 supercab 4x4 for cheap?
wookie13
Fenton Missouri
5.4 TRITON V-8
I am posting this for my cousin as his PC just died. he has a 86 supercab 4x4 and is wanting to put 31/10.50/15 tires on it as it NEEDS tires badly. he cant afford a lift right now so is there any way of getting 31's to fit with a SAFE and cheap way to lift?
jimmy1979
U.S. Military - Active
Fort Lewis, WA
4.OL
bcost882
5
The Queens Country.....
3.0L, 1.6L
uh you could get coil spacers but then you would need an alignment, and shackles. but it would still be atleast 150-200 for just the spacers and shackles. so you gotta specify budget. but otherwise cut the fenders. and they might still rub if you mount them on stock wheels
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
I got my belltechs for about 60$, and the washers I needed for coil spacers for about 6$. Do a self alignment, and BAM....inch or two of lift for 66$. Dont know where you think its going to cost 150-200.
bcost882
5
3.0L, 1.6L
my bad i was goin for the not home fabbed price
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
Cut the fenders is the cheapest.
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
Epoxy hockey pucks together for a cheap body lift. You can find them on ebay cheap
r1hatman
4
Knoxville, TN
2.8
F 150 springs from JY $22.00,(2") 91 exploder leafs JY $34.00,(11/2") 3 degree shims @ AZ $15.00, alignment 50 -100 bucks, AZ lowering shackles(2") $30.00. =200.00?
Oh yeah, $18.00? new hardware for the lowering shackles cause the factory bolts won't go through the shackles bushing holes, make sure you get grade 8!
+218.00 + or - a few
wookie13
Fenton Missouri
5.4 TRITON V-8
I was thinking of the coil spacers and maybe a block in the rear. he has aftermarket wheels- Cragar soft 8's I think in a 15x8 its just an ongoing project as we have had to replace the tranny and motor mounts{its a 2.9} and it needs some odds and ends b/c he is overdue on his inspection. he bought it w/ a relative good body/motor/ interior but the trans crapped out and only working on it every other sat. sucks as he has to work every other weekend. i told him just to cut the fenders but he doesnt really want to do that. he is going to get an alignment after getting the tires on anyways so that won't be a problem. My dad gave him his old spare a 30/9.50/15 on a old f150 wheel but I know he has to get a 5x4.5 bolt pattern wheel for that to be used.
r1hatman
4
Knoxville, TN
2.8
Yeah, I didn't either. I will. I just want to take the fenders off and do it right and curl the metal so I can reconnect the fender skirts then I put on some Rough Country fender flares!
Grunizzle
01/2013 OTOTM Winner
Albuquerque, NM
4.0L V-6
Where do the shims go and how do you put them on?
-Nathan-
39
HO 5.0 / 7.3 PSD
between the leaf spring and the axle perch, it will provide you with a better pinion angle.
Grunizzle
Albuquerque, NM
4.0L V-6
oh is there a part number for them?
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Dont you need to extend the steering column too? I thought I read that somewhere.
