Alternator Wiring?
catatau
I just bought a 2000 ford ranger that’s been swapped with a 1998 ford explorer 5.0. The wiring on it is no good. I’ve got an alternator with a plug that has two wires. Does anyone know where those go to? My battery isn’t getting charged.
deathbypsi
06/2012 STOTM Winner
MTOTM Winner
79
Mich
2.3turbo
Hook the yellow to the main power stud and the green needs to see 12v with the key in the run position.
catatau
Whats a main power stud? Like the mega fuse?
8,371
The B+ terminal on the back of the alternator is a "Main Power" stud, and the one he was referring to I think
Yellow wire would normally run to a 10-15amp fuse in engine fuse box, it would be labelled ALT, it has 12v all the time, like the main stud
Green wire should go to dash board battery light, it has 12v when key is on, and if alternator does quit working then Battery Light would come on, like it should do with key on engine off, because alternator is not work at that time :)
usmc2003ranger
Hey guys, I am bringing up this question too. Does anyone have a photo of exactly where the yellow/white wire connects? A photo of where the green/red wire connects?
So on the swap writeup, it says:
"The short Black wire with White stripe from the plug is now going to be used for the Yellow/White alternator wire."
"The 1996-1997 Explorer harness has pin 41 empty. This is a Light Green/Red wire for the alternator light. From the alternator, connect this wire to the Ranger side of plug 41 or take the wire and pin from the Ranger motor plug and connect it through the plug."
But, I found that the short black and white wire is in plug 41 on the ranger side. So does the yellow/white wire connect to it, or the green/red? Then where does the other wire go?
8,371
The yellow/white wire FROM the alternator does not go into the cab, it goes to engine Fuse box, it needs a 15amp fuse that has power all the time
Light Green/red wire FROM the alternator does go into the cab and to the instrument cluster, pin 3
It only has power with key ON
Black/white stripe wire is a Ground in any circuits I have seen, Black/red stripe can be 12v
Alternator doesn't have a ground "wire" it is grounded via the case bolted to the engine
Ford reuses wire colors in different circuits, so make sure the wire you got is the wire you "think it is" :)
usmc2003ranger
On the harness, pin 3 is used, would I just tap into that wire?
usmc2003ranger
Oh wait, it goes to the in-cab fuse panel to the instrument cluster fuse?
usmc2003ranger
From my ranger manual, I have this...
Fuse 11: 7.5A Instrument cluster, 4x4, Main light switch,
Truck Central Security Module (TCSM),
GEM
Fuse 26: 10A Battery saver relay, Auxiliary relay box,
Restraint Central Module (RCM), Generic
Electronic Module (GEM), Instrument
cluster
On the charging diagram in the manual is shows it going to a 7.5 fuse.
8,371
Pin 3 on one of the instrument cluster connectors, not the firewall connector
2003 Ranger wiring
Fuse 11 7.5 amp in cab fuse box has a yellow wire that runs to pin 2 on instrument cluster C220 , same C220 pin 3 has the green wire that runs to alternator
So
12v(key on)----Fuse 11---------(yellow)----------(pin2)instrument cluster(pin3)-------(green/red)---firewall--------(green/red)----alternator's 3 wire connector
That's the Battery Light circuit in 2003
usmc2003ranger
Awesome. Thank you. So the easiest thing will basically be for me to take the cluster out rather than wire track?
