adjustable bushing?
swynx
9
lewiston idaho
Mazda
Can any one tell if this is an adjustable bushing? I can't get it out and I don't have a big enough tool to turn it.
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Not adjustable.
swynx
9
lewiston idaho
Mazda
Awesome thanks.
4
Oneida, Wisconsin
Mazda
3.0L
It should be a offset bushing which would make it adjustable in the fact that camber and caster are changed at the same time not individually.
bigmark303
RI
4.0, 2.5
its a fixed adjustable bushing. You can only spin it 180 degrees.
For example if its a +2 degree bushing you have +2 degrees positive camber, and you can only spin it 180 degrees to achive -2 degrees camber. Those fixed adjustable bushings only have two setting a positive and negative fixed setting. Spin it any other amount that does not line up with either of the settings and youll have a real funky alignment.
swynx
9
lewiston idaho
Mazda
Alright. I just finished shimming my springs to get rid of the camber I was having. But wasn't sure if I needed to buy new bushings for the alignment down the road. And if I did I was just going to stack a lot of washers until I get the 132x coils.
bigmark303
RI
4.0, 2.5
get yourself a set of the moog 0-4 degree fully adjustable two piece bushings. 4+ all the way to -4 and everything in between. Easiest way to get the truck back into alignment instead of shimming and fooling around with spacers. Youll need them once you get the 132x springs.
I have two sets of 132x springs if you are interested $100.00 shipped. Used them for about 6 months and went to 136 springs.
swynx
9
lewiston idaho
Mazda
I might have to take you up on that offer. Ill know in a few days and ill pm you if I want them.
