The A4LD was used from 1985 thru 2011 in Rangers and other Fords
So a 26 year run, so nothing at all wrong with the transmission
A4LD was 1985 thru 1994
4R55E was 1995 thru 2000, had a different valve body
5R55E was 2001 thru 2011, had an extra sensor on the outside
Same internal parts
The main problem with the A4LD was transmission shops at the time had NEVER EVER seen an Overdrive automatic, it was close to the first one, AOD was first, 1980-2014, for full size trucks
Same fate suffered as the AOD, poor rebuilds or repairs
Both got a bad rap
In any case you don't need to "upgrade" anything unless you will be heavily off-roading or racing
Just a proper rebuild will get you 200k miles at least
Poor rebuild, 12 to 18months at most
If you don't get at least a 2 year warranty from any trans shop walk away
Yes, an M5R1(M5OD-R1) manual from a 2WD 3.0l Ranger or Mazda B3000 will work for you
M5R1 does not have a detachable bell housing so each M5R1 is engine specific
1991 to 1997 will have speedometer cable hook up, 1998 and up will not
for daily driving i would rather have an auto...
i have to agree....in this guys application...just find a shop that deals with them and go there.
but...the life span that ford used it being an indicator of it actually being an ok transmission... i dont agree with.
low....low power...meh...for reliability. you can not expect them to make it to 200k. 250 k is MY benchmark...so that is pure subjective crap...but my main range as to whether or not something is worth owning.... because 60 k per year is easy for me to do..... which of course....250k is three times as far as ford needs it to go....so that is a thing.
just like the 6.2 diesel.....the a4ld...is a long lived pile of garbage....there is nothing about it that is good....unless used in a tiny miniscule range. these things have a well deserved bad reputation...they can be built to last a bit in certain applications. but a supercharged 4.0 and a4ld will not be reliable.
the 5r55 is improved in ways that work...still low power. these can take some longer term abuse from a supercharged 4.0... the high power units that they tried to put behind v8s was a total disaster....there are 4 versions of these iirc...
the early case aod needed alot of work to be used with anything more then 40-50 hp over stock power. for the 80's it was on the margins....but they made some serious improvements in lube in 88-89 that was desperately needed even for those nutless engines. when it went computer controlled it was a game changer to be sure. the 2 in band and diode sprag really made for reliability.
the 6r80 otoh.... made up for these earlier units. of course...there were issues...but they at least offer ideal range and actual capacity for power handling ....
and the irony....is they are perfect for lower power engines...because they have so much range. i am actually thinking of fixing the shortcomings of the 6.x diesel with the 6r80. ultimate turd polishing.
of course it, the 6r80 or 60 uses too much power to make it worth adapting to a 3.0..so...thats a no go....
but the a4ld....as long as a good builder works on it though....you will be fine. but that 2k build tag for a trans that may have to go in a few times for adjustments...for an old 2000 dollar truck, is a bitter pill.
