Accessory fuse box
kenwheeler
Harrisburg, PA
2.9
I'm building a console to hold my additional light switches, CB, extra gauges, etc. I want run a power supply to a separate fusebox inside (easier access to connections) the new console. Can I run my hot wire directly from the battery?
martin
26
St Bruno, Quebec
1991
Yes but an inline fuse near the battery would be a very good idea.
koda6966
61
The green part of NY.
2.9
I agree, run a fused line from the battery to the new box. Also, make sure you check voltages on everything. I ran a new line to a fuse box in my Zx2, and it kept busting 30A fuses when my draw from my Cathodes was only about .7A and was previously run in my Ranger to a 2A inline fuse with no problems. I am yet to figure that one out, I just unhooked it for the time being.
You can get some good deals on Amazon.com regarding the fuseblocks. Here's a picture of MiniATC block I was mocking up in my car. I picked it up for about $8, although if you have room I would recommend a fullsize fuse block as that may also be my problem.
This one is a little more pricey, but I plan on buying it when I do some more work on the interior/exterior.
http://www.amazon.com/BUSS-ATC-FUSE-BLOCK-POS/dp/B000UKH0RQ/ref=sr_1_1?ie=UTF8&s=automotive&qid=1284384608&sr=8-1
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
i think i'd opt for a large 60 amp or so inline circuit breaker installed close to the battery. they are very heavy duty and much easier to deal with than fuses. just my $.02.
kenwheeler
Harrisburg, PA
2.9
Thanks for the circuit breaker or inline fuse close to the battery tip, I hadn't thought about that. What gauge wire should I use (battery to fuse box) and what size fuse or circuit breaker?
