- Aug 7, 2007
- 18
- Opelousas La.
- Ranger
The 300 flywheel may be the same diameter as the 302's but it cannot be used on a 302 as there's no counterweight. If you have block plates for both diameter flywheels, it's a simple matter of figuring out which flywheel diameter you need. Then there's the matter of the pressure plate bolt pattern, a pressure plate for an 11" clutch will not bolt up to a flywheel with a 10" or 10.5" pressure plate pattern. You can however use a 10 or 10.5" clutch disc with an 11" pressure plate, but the reverse is not true.
