'99 Explorer 5.0 - '99 Ranger
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Depends on where it is at.
fastpakr
2,840
Roanoke, VA
Craig0320
225
Mississppi
Yeah to far for me. Wish I could make it.
Craig0320
225
Mississppi
What gear ratio is in your truck?
fastpakr
2,840
Roanoke, VA
4.10. Not terrible, but a little shorter than I'd like for 33's.
Craig0320
225
Mississppi
I was just curious. I am turning 2,200 rpms at 70mph with 3.73's
fastpakr
2,840
Roanoke, VA
I'll have to check, and do some math to convert it since the speedo is off.
Having some issues with the transmission not wanting to be in the correct gear. Seems to want to hang out in a higher gear than it should be most of the time when I'm asking for power, so I'll be at mid throttle trying to accelerate but stuck at less than 2000rpm unless I floor it to force a shift. From the reading I've done it's probably a function of accumulators and solenoids but I want to knock out a few things before draining the transmission and looking at all that.
Craig0320
225
Mississppi
It does sound like a solenoid. Fluid is full(I am assuming but not overfull) causing cavitation of the fluid thus creating a slight pressure loss to solenoids?
Craig0320
225
Mississppi
Did you install the mountaineer leafs on the back of your ranger. I am going to do this tomorrow to have one more thing out of the way when we weld the rear end up and stick it in.
fastpakr
2,840
Roanoke, VA
I put in a set of leaves out of a Sport Trac. Double check the bushings on each end - they can be kind of a pain to find the right ones and now is the time.
Craig0320
225
Mississppi
Hmm. Didn't know they were different. These are out of the 4 door 2wd donor. I will have to do some more research.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,789
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
What's the status of the Ranger?
