LIFT UPDATE!!
Finally got around to getting 'er lifted!
Went out and bought a set of F-150 leaf packs for the rear. My original plan was to keep the main leaf from the X and swap the rest, but as it turns out, the other leaf pack wasn't as thick and was shorter.
So I came up with a plan B and added leafs 3 and 4 from the F-150 pack to my own where they'd fit.
So now I'm running around with 6 leafs per side including the overload leaf.
Still rides surprisingly smooth to be honest.
Anyway, enough with the chit chat and on to the pix.
Here it is before...with measurements. Rear first then front.
A pic of the F-150 leaf packs
You can see they came with 5 leafs
This little sucker had to go. Cut-off wheel made quick work of it.
Here it is with the main leaf separated from the rest
I didn't bother taking pix while I was working because it was all rusty and pissing me off beyond measure.
Here's what the driver's side looked like after completion.
New measurement, rear then front
I could only lift the front 1" due to the drivers side torsion adjuster bolt bottoming out. So I'll have to go see if I can get a longer bolt that'll fit.
After pic.
Also had someone spying on me while I was working....
Keep your eyes on this page tomorrow for the Pro Comp wheel install!
Thanks for lookin!
