black_demon69
- Jun 30, 2013
- Reaction score
- 142
- Location
- AZ
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0l
- Manual
- 2WD / 4WD
- 4WD
ok here is the problem
truck stalls very intermittently always when hot out and truck has been running all day. let it sit for 15 to 20 min and it starts and runs fine.
i have replaced the crank sensor, tps, map, iac, ign mod, coil pack, plugs, wires, fuel pump, fuel filter, all relays, fuel shut off sw, and ecm.
there is no loss in power prior to stall and no check engine lights no codes and gives no warning. i have noticed i can reproduce problem if i sit and idle for 30 to 45 min on a hot day..
could it be a vapor lock, there is a small leak in fuel tank right at the top only leaks when full could that be the problem? no egr valve on engine
im stumped
im stumped
