94 a4ld in 2.9L knocking
Lkorecky11
I recently rebuild the tranny and it seems to knock in second gear. I can hear it when in drive at 25mph and when I put it in second. In first I don’t hear it. One other issue is now I can’t find overdrive and yes the linkage is hooked up correctly which is strange. I also adjusted the bands. Any advice is appreciated!
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
Sure its the trans?
Either way, it could be a busted flywheel or a torque converter on its way out, id lean toward the converter.
Lkorecky11
Exactly how would I know which one I replaced them both when installing it
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Are you sure you tightened the torque converter bolts?
Lkorecky11
The four nuts I put threadlocker on them and tightened them to 35ft lbs. I hear it in park at a certain rpm and mainly in second.
