- Sep 14, 2007
- 2
- Calgary Ab Canada
- Ford
Strange, I try to be nice & you decide to be rude? Good on ya ...Just simple physics? Yeah, that you have an incomplete grasp of.
No power is actually "lost" through driveline mass, however it affects the measurement of the power precisely as you describe.
But the power didn't actually go anywhere.
and the apparrent loss isn't nearly as great as you think it is.
you've probably been misled by others talking up their stuff the same way.
Just between you and me the picking at your posts isn't nearly what it would be if you have waved a "red flag" like saying (for example) that you had a "3/4 race camshaft" try that one sometime and the fecal material will really splatter as it hits the rotary ventilation device.
AD
I must have managed to touch a nerve if you've decided that insults will help you prove a point!
You're also now using semantics to prove a non existent point. & you're incorrect.
If this were a step test where the engine was stabilized & loaded at set rpm points to take the measurement, the driveline mass wouldn't be an issue, only frictional losses would. The measured values would reflect this.
But this is an acceleration test, power is required to accelerate the mass of the driveline & the power used won't be measured. As a result this test will show lower figures. Or a "loss" (oh heaven forbid .... I used that word!!)
To say the power didn't actually go anywhere is flat out wrong, it was used to accelerate the driveline.
So what exactly is the point you're trying to make?
Oh ya .... I remember ... I have an incomplete grasp of simple physics .... right!!
