Thanks Will, I attribute the low mph to the brick like shape of my truck.
If you run the 1/8th mile #'s through your program you'll see a slight increase (9.03 @ 76 mph) & although I have managed to run back to back 14.37's @ 95 mph, usually the mph is 91-92
Something else to take into consideration is the effective altitude. In Calgary The effective altitude can range from 4500' to 6500', at these altitudes the engine is only able to produce 85- 90% of it's power. 200hp here would be at the very least 220 at sea level.
Also, I'm not in disagreement about the gear issue at all. As a matter of fact, I have an 06 R/C 4.0L 4x4 that has 31's & 3.73's that I'm installing 4.56's in as soon as possible. It probably doesn't need them, but I know that bigger tires are in it's future
My intention was only to answer what I read as the question.
But I do have something to add,
Regarding the driveline loss; Friction is only part of it, the mass of the driveline is also a factor. There's close to 300#'s that link the flywheel to the rollers on the dyno(transmission, diff & wheels), Considering that the test only lasts a few seconds, it takes a considerable amount of power to accelerate this mass through the test range. The power required to do this isn't going to make it to the rollers on the dyno, & therefore is lost.
No convenient numbers, just simple physics.
AllanD is concerned with possible drivability issues with this cam. You definitely don't want a cam that has a tendency to make the engine surge while you're trying to tippy toe through rocky terrain. The 422 is a very mild grind, it still pulls 20 in/hg of vacuum at an idle of 750rpm & has only the slightest lope. By 1000rpm under very light throttle it pulls 23 in/hg of vacuum & is absolutely smooth.
Here is a link to a video of me doing a couple 1/4 mile test runs on a dyno shortly after swapping the cam. This is with the factory ECU & stock program.
Enjoy!
http://members.shaw.ca/tomak/quartmile.wmv
