Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Idle RPMs are controlled by the computer via the IAC Valve so there is no "user adjustment" available for that.ive read quite a few different idle reset procedures....any you guys prefer or recommend
Surrat, when you removed EGR system did you plug the holes on the back side of the heads where the EGR tubes connected, takes a 14mm plug. This will cause a vacuum leak if holes are not plug.
