89 Ranger with no brake lights
Ducman491
Hello everyone,
A friend bought his son an 89 Ranger ext cab 2wd 6cyl for his first vehicle and we are having some trouble with the brake lights. The tail lights work as well as the turn signals and reverse lights. There are no hazard lights or brake lights. I tried testing the switch at the brake pedal but there was no power going into the switch and I ran out of time to trace the wire going into the switch.
My question is where does the power come from to supply the brake switch? This poor truck has had the harness hacked up pretty good so this may prove to be a bit challenging.
Thanks
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
First check all the fuses, next hot wire the switch for the brake lights to the battery and then check and see if you have brake lights ,if not trace all the wiring at and below the rear bumper because you may have a ground problem or dirty connection at the trailer wiring. The previous owner may have hacked up the tail light wiring to install non factory trailer wiring. Hope this helps.
8,372
Brake light and hazard lights often shared the same fuse, 15 amp, it has power all the time, not key on only power
It will be in cab fuse box, for sure
Try Fuse #1
Yes, because it has power all the time it can blow any time, and especially if Trailer wiring has be butchered, lol
Ducman491
Thank you gentlemen! I'll let you all know what we find.
