reef93
- Jan 18, 2013
- 0
- Robbins, NC
OK got a long one here so here it goes......89 ranger 2.3 auto. Was driving my truck to work one day and noticed the check engine light illuminate, next thing I know the truck stumbled and smoothed right out. I get to work pop the hood look under and notice the little connector that hooks up to the capacitor on the coil pack had gotten against the heater hose and looked as if it got hot. I zip tie it away and truck runs fine for a few weeks. Problem starts up again only this time its getting hard to crank like its really sluggish a few turns so i stop and try again then it eventually cranks right up. SO....I "assume" crank sensor. So I purchase a new crank sensor from Ford and decide its a good time to do water pump, timing belt, and tensioner. I get truck put back together it cranks up runs fine so I drive it around to see how it does. Get home and starts doing the hard crank again. So at this point I think it could be the Ignition Control Module. So I drive the truck back to the shop. I have a 93 mustang 2.3 that had an issue but I havent figured it out and just let it set. So I steal the ICM from it.....same part number. So I swap the modules. The truck cranks right up and shuts off. Every time. That was the problem the car was having. SO I assume I have figured out the problem with the car and think the module was bad. I swap them back and now the truck will not crank and the fuel pump constantly runs with the key on engine off. Had both modules tested and both tested good........SO ive changed crank sensor, swapped out coil packs, and had ignition control modules checked and both tested good.....So im at a loss at what direction to try now. Any help would be greatly appreciated!
