85 BII Starting problems
Ryan_D85
SE Kansas
2.8
1985 BII with a 2.8 and five speed. Was grinding a little bit when I bought so I put in new battery and starter worked fine for about four months. Then all of the sudden starter sounded like it quit engaging replaced starter again but still has same problem if I turn the flywheel it grinds hard once but then just spins after that. Checked flywheel all the way around no teeth missing or bad spots cannot figure out what is going on need some help.:icon_confused:
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
You may need to shim the starter. I was having the same issues but found that the starter bolts were incorrect and wouldn't stay tight so I purchased new starter bolts and installed, torqued them down and haven't had a problem with the starter not engaging in about 2 months now.
Ryan_D85
SE Kansas
2.8
Thanks for the advice went and got factory starter bolts and now it starts with no grinding and starts everytime.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Cool, glad you got it fixed. I've been driving mine around for about a month and a half since replacing the starter bolts, haven't had a starting issue since. The right bolts make a huge difference.
