Okay 92xplorer...here we go!
I tried to keep it simple...I know this will be clear as mud!! lol Don't wory to much because if you cut a wrong wire you can always re connect it. We did! Mine is a little different because we used a 4 pin GM HEI module instead of the duraspark box.
Driver's side
1. 8 wire rectangular plug didn't do anything other than cut the Red/green stripe wire and splice to red wire on positive side of coil. Now we have a pigtail coming off that connection going to the B pin on my HEI module.
2. Green wire form Neg side of coil ran to C pin on HEI module.
3. There are two round plugs, took the red/blue stripe wire cut from each and spliced those two together.
4. After removing the condenser from the side of the factory coil, ran a ground wire from coil and grounded it through one of the mounting bolts on my HEI module.
That is it on Driver's side. Now to the Passenger side which has alot more.
1. 3 wires coming off the distributor,
a. Black/white stripe, this is ground, grounded to valve cover bolt.
b. Purple wire, this we ran up back of firewall to the W pin on HEI module.
c. Orange wire, again ran this up back of fire wall to the G pin on HEI module.
We ran both of those wires in a heat resistant fabric sleeve, each wire was splice to a longer wire to reach other side of engine compartment, I might of gotten them mixed up because splices were in the jacket, so if you have any problems try swapping there positions. Was pretty sure I got them correct though.
2. Power for electric choke, I tied it in to a switchable off back of alternator, black/white dashes.
3. Now for the passenger fender well. My truck had 3 looms here, 1 large wire bundle, 2 smaller wire bundles. 1 small loom went down under the engine, I left that one alone. the other small loom went over the top of the motor to my AC condenser. The big loom, all wires were cut except for 4. I kept a solid red, green /purple dashes, solid orange, and orange/yellow stripe.
That was pretty much it. Looking at my wires it appears the the temp sensor, alternator wires, oil pressure all come form driver's side, they are loomed into the wires from my 8 wire plug. I left those alone
After I was done, I loomed everything back up and made it look neat.
I hope this helps, sorry if it is confusing, if you have any questions post on this thread but then send me a private message. The PM gets sent to my email and I will get it on my blackberry and can respond quicker.
