8.8 31 spline axle w/5.13 locker and c-clips
Jay'94
4
NA
Alright all you experts out there! Ran into this one, what's everybody doing?
Have a '99 8.8 31 spline explorer axle, all new seals, bearings, blah blah, and installed 5.13 gears (originally 3.55 open). Tried to put in a mini-spool (yeah whatever they're cheap) and couldn't get the c-clips back in because the ring gear is too damn thick. Thought of running c-clip eliminator kit, but then I lose the e-brakes inside the disc brake rotors. To get around this one have thought of installing a "line lock" in the rear brake line to still have "an e-Brake" (doubt that shit's legal though, but who really cares right now I'm in KY and retiring in farmland AL in 6 months)!
So wasn't thinking well, returned the mini spool and ordered a Powertrax lock-rite. Still can't get the c-clip back in.
So those of you running 8.8 31 spline rears with disc brakes and anything geared lower than 4.56, what are your running for lockers or L/S?
I really don't want to order a Detroit but coming real close to dropping the coin.
Oh and I really don't want to lincoln lock it.
:icon_confused:
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Running a Detroit in mine with 4.56's
Combs Customs
West Chester, Ohio
Ford / Ford / F
4.0L / 4.0L /4.0L
Im running Detroit also with 4.56.
You can't get the c-clips in or the pinion shaft?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Grind the ring gear teeth slightly so you can get the crosspin in past it (doesn't hurt a thing, the very tips of the teeth where you grind the pinion never makes any contact with anyway).
I had to do this on mine and no problems (it's actually pretty common practice).
Last, I would weld it loooonnng before running a POS mini-spool in a c-clip axle. c-clip mini-spools are a whole bunch of little pieces that like to break (they are not a single solid chunk like for non-c-clip apps).
Jay'94
4
NA
confusion
4x4junkie;
what locker you got lockin them 5.13s?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
He's got ARBs.
Jay'94
4
NA
