5.0 fuel pump please help
stiluv
01/2014 OTOTM Winner
ASE Certified Tech
nevada city, california
5.oh face oh oh oh
Solid Axle Swap 4x4
I'm almost done swapping a 98 5.0 in my 99 ranger. I have to change the fuel system to a return style system. The expo pump won't fit the ranger tank and the ranger pump puts out to much presure. What pump do I use? I was counting on using the expo pump so I went on with the swap I really need to drive it home tomorrow. Please help thanks
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The ex tank should fit the ranger frame. If not, just run it. If you are running a return style system, it should regulate the pressure by them for...
SVT
stiluv
ASE Certified Tech
5.oh face oh oh oh
Solid Axle Swap 4x4
So just run the ranger pump?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I would. Return style needs 35-45, while returnless needs 55-65. The pressures are not that great of a difference, you might run slightly on the rich side, but that won't hurt the engine...
SVT
stiluv
ASE Certified Tech
5.oh face oh oh oh
Solid Axle Swap 4x4
Thank you I will try it and post the results
sab24711
Hey guys im in the process now of gettiń my fuel pump sorted out. I was wondering how it worked out for you? Im ready to add a return line but i figured the regulator would just use the gas it needs and return whats left back into the tank.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
You're correct in your thinking. What's your specs(year or truck, year of engine/ECU/fuel system)?
SVT
sab24711
99 ranger 4.0 xlt 4x4 swap to a 96 explorer 5.0 i have the fittings and fuel line to install into the housing in the fuel pump. Thank you for getting back to me so fast really appreace it
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
The 4.0, is that the ohv or the SOHC? I'm guessing you have the SOHC which means you have no return. You can simply get a fuel rail from a 98+ 4 banger truck that had return lines, or run your own return 5/16 lines, and grab a 4 banger fuel pump assembly...
SVT
sab24711
Sohc no return line. 96 ranger has a return line . Im using the 96 fuel rail making a return line to the tank. I hope the diffrence in pressure wont mess up my fuel regulator
sab24711
The 4 banger rail wont work cause i still have 4 more injector
Whats the psi in a 4cyl fuel pump. If i can i would just swap the pumps
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Not the rails, the frame mounted lines. The pump has the capacity to run a V8 without maxxing out duty cycle. Another option is to grab a 99-01 fuel rail and run the motor returnless. There's a couple other steps for this if your interested...
SVT
sab24711
Okay so what i have now is a return line plumbed to my tank already. So i should get a 98+ 4 cly pump installed? Whole assembly or just the pump.
I take it running the o.g pump at 65psi is to much for the 96 5.0 42psi fuel Pressure regulator
ty.thompson1981
I have a 97 ranger that I did a 302 swap on from an 89 mustang GT. For the fuel pump, I used a 255 pump that I had in my 98 cobra. What I did was pull the the stock pump assembly out of the tank and disconnect the actual electrical portion of the pump. (the silver cylinder). I pulled the cylinder off the 255 cobra pump assembly and wired it to the ranger's existing wires, cut the basket a little to fit the cylinder, dropped it in the tank. Haven't had any problems with fuel at all. Hope this helps.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
No, its not. That's the regulators job, the pump delivers the fuel to the engine, any excess is returned to the tank...
SVT
