5.0 EFI gas mileage question...331 stoker
bottledgt
heres my combo...94 x cab ranger,331 stoker EFI,big valve mild ported E7's, explorer intake,comp HR10 cam,1.7 rockers. 70mm throttle body, 24 lb injectors,c&l mass air meter,10 deg base timing.AOD trans,dana 20 transfeer, 8.8 with 4.10. 33 inch thornbirds. fuel pressure is at 40 lbs with vacuum off at idle. 255 lph pump.
NOW, hopefully i didnt forget anything. i didnt expect great mileage, but 10mpg is absolutley killing me since im driving really easy and not even really using the motor at all. it sees MAYBE 4000 on occasion. ir runs fine and everything is great, but sucks fuel like no tomorrow. anybody else have a similar combo to compare? i figured with EFI it would at least get 14-15 being easy on it. that would make me happy actually
bottledgt
well i just may have found something. i was sitting here thinking and it hit me that i never did put a BAP sensor on the truck at all. went and looked and sure enough found the BAP sensor harness plug hanging. havent drove it yet but i hope this fixes something. im not sure how critical this thing is but i know it has some to do with fuel metering i think.
GETUSUM
I dont think that will make the mileage go up much. What is your A/F ratio at idle? Ever been tuned? Another thing that kills it is the aod and big tires.
Pt_Ranger_V8
FullsizeFreakin'
Forum Staff - Retired
in ur g'rage, uzin' u're toolz
19 something
and the fact that you're running a big cammed stroker motor - I bet 15 will be the best you can do.
bottledgt
actually i think its helping...i havent filled back up yet to check, but it seems im going farther than i used to so far. im thinking with that unplugged the ecu goes into a default 'rich' code. it doesnt seem to be running as fat now.i dont smell gas anymore while driving. i know 15 is the best i can do, i just want the 15 and ill be super happy. 10 is total crap with me being easy on it. it does seem to operate much smoother now. i will find out the truth soon enough though
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Dump the thornturds for some radials... like some 33x10.50 or 9.50 BFGs... That will reduce the rolling resistance and improve mileage some.
bottledgt
yeah ,thats the next step actually. already though about that. gonna wear these out first though
mudranger
Florida
I'm getting 17-18 highway out of the 5.0 HO w/a carb, 32" BFG muds .410s and a locker with an AOD.... (as long as I keep my foot out of it).... So even with the cam, some more streetable tires should help you get 15....
bottledgt
well as of now, im getting about 12. still aint great but i guess its what i got. i may have comp grind me a better cam to suit the truck. this cam seems to have more top end power than bottom, which is exactly oppostie iof what i want. that may help as well. iva also got 1.7 roller rockers on it. i may swithc back to 1.6 and see if that makes a difference
v-8power
31
Huntington, In.
You wont have a "Lot" of bottom end on any 302 based motor as far as i have ever seen. Just my .02 though
bottledgt
ehh. i disagree. unless i dont know what you mean by ALOT
bottledgt
well after many hours of testing wires and sensors and ohmmeters i have determined that my eec is bad. i was getting a lean 02 code so it was dumping fuel to it. i changed the eec to another A9L and it straightened it out. it even starts and runs when its cold now, where as it wouldnt before
bottledgt
huh? right now i have 19 lb injectors with a stock mustang MAF, but i also have a C&L meter to go with 24s ill put back on probably after i see what mileage i get with these. the MAF was not the problem . the eec was crap and wouldnt read 02's so the eec was dumping fuel on it trying to correct a lean condition that wasnt there
