4 wheel drive problem
wrestling211989
Ive done some off roading and not been very careful which is stupid. ive hit a few bumps to hard and things like that. But now when i switch from 4 wheel to 2 wheel it sticks sometimes but eventually comes out. any ideas on what could be wrong and the cost it would take to fix?
Thanks for Any suggestions
c_note
September 2009 OTOM Winner
back in San Diego, CA
Ranger/Explorer
4.0 sohc
vehicle specs? just to have a better understanding.
97RangerXLT
TRS 25th Anniversary
3,964
Fishers, IN
2"
31"
If you got the auto hubs, you may have to back it up several feet after you take it out of 4 hi to get the hubs to release. As I understand it, this is normal.
AJ
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
when your switching, make sure that you have driven in a straight line for 50 feet or so, so that there is minimal tension between the front and rear axles.
what is likely happening is either your trying to disengage right after/during a turn or possibly the tire pressures are significantly different between the front and rear of your truck which could also lead to binding.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
oh i didnt realize you double posted. look at your other thread for the answer i posted.
surffishin07
Rockingham, North Carolina "The Rock"
if is an electric transfer case check the shift motor i had that problem and had to take my shift motor off to get home. not fun when it finally quits
