4 link SAS+lift
Ford78
December 2012 OTOTM
Iowa
351w
How are u liking the rear welded up for a daily driver use and would u do it again?
Going to be swaping my rear over to 5.13 in the next cople so it matches the front and so i can have my 4wheel drive back. Just thought i could save a cople of bucks instead of geeting a spool.
cdawall
U.S. Military - Active
5
Ellsworth AFB
4.0L V6
I have no issues with it. There is no driveability difference between the spool and a welded rear. It has to be done correctly though mine is the spider gears welded together and then welded to the housing.
Ford78
December 2012 OTOTM
Iowa
351w
Thanks, I plan on going this route instead of the spool so i can spend the extra cash i save on other things.
cdawall
5
Ellsworth AFB
4.0L V6
I assume your rear is a FF D60 30 spline? You might smoke some shafts with a little larger tires.
Ford78
December 2012 OTOTM
Iowa
351w
Yea the rear is only 30 spline and if i do break it to often ill just swap to a ford 10.25. Plus i dont have the heavy right foot that i use too have when i was younger and the 3.0 is not a power house, so im thinking i should be fine for a while.
cdawall
5
Ellsworth AFB
4.0L V6
Ford78
December 2012 OTOTM
Iowa
351w
Time for a heavy duty shaft!
cdawall
5
Ellsworth AFB
4.0L V6
Going to grab a steel shaft tomorrow. If I have issues again I will cut the ends of and get a piece of dom.
cdawall
5
Ellsworth AFB
4.0L V6
And the events leading up to broken things
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Go .120 DOM, I made a few and while not invincible it worked the best. My .250" wall shaft was heavy, hard to balance and you could feel the power loss due to rotational mass in the driveline.
Ford78
December 2012 OTOTM
Iowa
351w
Did u smash the fuel tank too?
Ford78
December 2012 OTOTM
Iowa
351w
Did u have to modifie your transmission crossmeber for your front drive shaft or does it clear it ok? Didnt see if u had to to in you thread. I hope to get my front shaft next week if everything goes good.
cdawall
5
Ellsworth AFB
4.0L V6
Good to know thanks
Front and rear crossmembers are modded for the driveshafts to clear.
cdawall
5
Ellsworth AFB
4.0L V6
Snagged a couple of parts today. The new shaft is out of an explorer going to have it lengthened and balanced.
No it's a plastic tank I just drug it a little they flex pretty damn good.
On another not anyone know how close a 2nd gen explorer tank is to fitting over a stock ranger tank?
cdawall
5
Ellsworth AFB
4.0L V6
Got a couple more photos from the run as more trickle in I will post them.
