shadow88
CLOQUET MN
FORD
Well tomorrow I'm going to pick up the donor, and some new parts, and then the 4.0 swap begins, wish me luck!
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
lchappyjr
Kalama, WA
Good luck, there isnt much to it. Yours should be easier than mine from what I hear. Mine has more power than before even with the 33's on. I swaped all power train and running gear.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
You will freakin love it. The B2 was meant for a 4.0
shadow88
CLOQUET MN
FORD
Any pointers? Should I pull the 2.9 first or the 4.0? Or don't it matter? I hate wiring so I'm a little Leary
shadow88
CLOQUET MN
FORD
Heres a question, my donor is a automatic, my b2 is a stick, I do have a harness from a donor with a stick, should I use the stick harness? Would this eliminate some trouble?
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
What year is the donor explorer?
you could adapted the automatic to manual. i am going to make a guess a manual harness would be easier. my swap was a manual explorer to a manual truck.
shadow88
CLOQUET MN
FORD
Both donors are 91
BroncoIIer
Oklahoma
4.0L OHV
I think you will need a computer for a manual because of the neutral safety switch
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
Both donors are 91
Look on eBay for Evtm's for the bronco II and the donor Explorer.
You never know someone here might have some copies too.
your swap should be a cake walk, most your work is at the white plug that goes into the firewall and its a matter of moving some pins around from what i have read.
I would pull the 2.9L and harness first then install the 4.0, make sure you take lots of photos and notes here things go.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I'm currently runnin an auto ecm . I have a 5 spd. It can be done.Use the harness from your donor, splice in your headlights and tailights. That should cover it.
shadow88
CLOQUET MN
FORD
Thanks for the info keep it coming, I'm starting to pull the 2.9 out today,
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
After you get your 2.9 out. Remove the 2.9 harness. Try to recreate the donors engine compartment in your B2. It'll look cleaner this way. Then install your 4.0
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
Splice the headlights? I thought the headlights setup were the same on the bronco as the explorer?
The tail lights should no be part of the engine manage harness.
At least it was that way with my 87, I don't remember removing anything for the tail lights in the 93 explorer harness.
Sent from my myTouch_4G_Slide using Tapatalk 2
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I used a gen 3 ranger for my swap, had to splice a little.
