4.0 ohv junkyard/cheap mods.
rab
merkur
Are there any cheap/junkyard mods for the 4.0 ohv; i.e. different model/year heads,intakes maybe other t.b. from a nother ford that fits,etc,etc
f3joel
Cheapest is the zip tie mod, no junkyard required...
I'm thinking lower gearing rear end, depending on what you have.
I know I want to replace my stock 3.08 with a 3.73.
Other junkyard mods , from what I have read, seem to be the 130 amp alternator from a 94/95 v6 mustang.
94-04 rear mustang disc brakes.
Rear sway bar from Bronco II.
JimRummy
Los Angeles, CA
245 CID 4.0 V6
What's the benefit of the Bronco II sway bar?
TxGasRacer
SE Texas
4.0 ohv
the advantage to running the Bronco II sway bar on your Ranger would be the bigger diameter of the sway bar from the Bronco II and I believe it to be a one inch diameter sway bar.
JimRummy
Los Angeles, CA
245 CID 4.0 V6
Oh ok. So it's just more rigid so you get less flex?
downer
4
97 4.0 OHV 4x4
99-04 mustang gt maf
rab
merkur
Just looking for strictly 4.0 ohv engine related stuff.
rab
merkur
SenorNoob
586
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Cheap and mods don't really go together..
That said, depending on what you have now and clearance, you might be able to swap oil filters for a little better (IMO) protection. I have one of the OLD style FL1A filters on mine. It's huge.
There is the possibility of using 95+ heads on an early engine (or was it the other way around) to bump compression. Supposedly you'd need to run premium then.
