351W/ZF/T-Case
Broaner
Madison, WI
Ford, Nissan
So I've got a carbed 351 out of an '81 F250. But its got an auto on it. If I were to use the ZF does the shifter end up in a good location for the stock shift boot? It also has a manual Tcase on it which I understand to be a 1356; is this correct? Its my understanding that Tcase will bolt up to the ZF but the larger size of the case requires clearancing. How will the shifter assembly on that fit? The stock 1354 will not bolt to the ZF; correct? What needs to be done for the speedo situation? I'm just kinda weighing my options here guys. Thanks for any input in advance.
wickedwindsor
351
The shifter comes out of the trans tunnel forward of the stock ranger location near under the dash. Check to see if it IS a 1356 and not an NP208. If it is an NP208, you are in luck as this should fit with no frame clearancing. I just recently put in a 1356 in my Explorer and moved the tranny mount to the passenger side by 7/8" to give just enough clearance for the xfer case to frame rail. I still ground out the frame a litttle anyway. The speedo arrangement is the same as stock 1354 so that is a bolt on. As far as xfer case shifter location...I used a shifter for an NP208 from an '86 F150 with AOD. This shifter ended up in the lower left side of the removeable trans tunnel plate. I had to cut and re-weld the shifter handle as it was hanging right by my right leg originally.
A lot of work, but not too bad if you can cut and weld. Oh ya, I used a front driveshaft from a '97 up F150 with 4.6 and hydrid ujoint to diff. Rear shaft was shortened by 1.5".
Moral of the story here is, definitely NOT a bolt in swap but very do-able with some patience and sweat.
wickedwindsor
351
4 Low
4 High
Drivers POV
No Plate
Tranny Mount moved over 7/8" to make room for 1356
projectnitemare
8
Osceola Mills, Pa
396W
I will have to get some pictures posted up for you. If you want to use a ZF you either need to install a body lift or fab a new trans tunnel. It will not fit nicely. I put a body lift on and I still had a spot that was pretty tight. You need the engine to sit as low as possible in the frame too. The shifter will need to be modified and the stock ranger boot won't work. It will be pointed toward the dash. I used an NP205 for stregnth and it happens to be smaller than both the NP208 and BW1356. With the NP205 you will need to grind a passage for the shift rail to clear on the tailshaft housing. The stock speedo stuff will work. If you decide to use a ZF it will be in your best interest to install the engine and trans already mated.
Matt
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
I'd really like to see those pics, mainly of the shifter positioning and of how the transmission sits in the tunnel.
Broaner
Madison, WI
Ford, Nissan
How far up under the dash does the ZF shifter come out? Is it something that is liveable or not really? Interested to see you pics Nitemare.
Is there a list of trucks that the 205 came in?
OT, on a 302,T5 setup where does the shifter come out?
Mac
183
C. Wisconsin
2000
199
With the T-5, the shifter comes out about 6-7 back from the stock location.
Dave - two hours North of you.
projectnitemare
8
Osceola Mills, Pa
396W
I will have pics today. The ZF shifter comes out pretty close to the dash. I cut and rewelded the bottom of the shifter where it bolts to the trans to fix this problem. If I didn't 1st, 3rd and 5th wouldn't be used. I forget the exact years of the NP205 but you are pretty much guranteed to see it in a 70's 4x4 Ford. The era is late 60's or so to the early 80's. It's very common but be sure to read the ID tag so you don't get a NP203. They are quite massive. The T5 setup the shifter comes out right in front of the set. 2nd, 4th and reverse will just hit the seat.
Matt
Broaner
Madison, WI
Ford, Nissan
Okay cool. Fabbing on the shifter doesn't bother me. What I'm really interested to know is how far forward of the stock console does it protrude from the floor?
projectnitemare
8
Osceola Mills, Pa
396W
Excuse the mess in there I need to get my wires looking nice yet; I just moved the MSD from the engine bay to the inside. Here are some pics.
Here's 1st gear
Reverse
1st gear top view
Why you need a body lift
Matt
Broaner
Madison, WI
Ford, Nissan
Thanks for the pics. So, does anyone know if on a 95 are the firewall to stock shifter dimensions the same as an 88? Body lift makes sense. I'm putting one on currently. But why not help by cutting that massive semi-triangular tab off?
projectnitemare
8
Osceola Mills, Pa
396W
I would believe those measurements are about the same. Maybe a little less room because that dash is bigger. The big tab on the trans isn't the only part that hits just the one that I can snap a picture of. The bellhousing is massive and the top of the transmission is massive.
ZF beside a M5ODR2
Matt
Broaner
Madison, WI
Ford, Nissan
If I were to make my own mounts would I be able to get the motor/trans combo back far enough to put the ZF shifter in the stock location? Or does the firewall and other sh!t get in the way? It looks like the ZF shifter is only a couple inches forward of the m5.
wickedwindsor
351
The drivers side head comes very close to the firewall when locating the v8 in a "practical location". You would definately have to cut out the firewall if you were to relocate the drivetrain rearward at all.
Save yourself a domino effect of hassle and locate everything in the "tried and true" fashion. Making a new gear shift handle or cutting and rewelding the gear shift is least of your worries and much easier than trying to cut corners elsewhere.
I used flat 1/4" plate steel to make my motor mounts which allowed me to place my setup in the most desired location. For me, this was the cheapest and most practical way for motor mounts. I'm sure using L&L mounts or factory Mustang mounts will give you equal or at the very least similar results.
Search other v8 swaps for pictures, collect a ton of examples and then decide which way you want to go. You'll find that no matter which route you decide to take, there WILL be some fabrication involved. There is no 'bolt in' swap involved.
mhughes165
9
302
the closest u will ever come to a bolt in swap into a ranger is stealin the entire drivetrain from a 5.0 exploder and goin from there
No members online now.
