351w headers help
Chris_97
so I ended up going and getting an engine from a guy who told me it was a 302. this engine was to be put into a 97 ford ranger but after I got home I pulled the intake manifold and it's a 351w. this build is going to be 4wd and I have the stock 1983 exhaust manifolds and don't think they'll work so I need some suggestions here? any help is appreciated
Chris_97
I already have a sm435 and transfer case that I wish to use but if it needs to go I can put in a c4 or c6
bf750
12
Ky
2. Crap
It is what it is
im going shorty headers on my302
Chris_97
that's what I originally was gonna use but the 351 is too wide
Chris_97
no suggestions? would 289 cast manifolds be small enough until I can get custom headers made?
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
I used hedman 302 swap headers on my 351w swap
Chris_97
did you have to bend them back to clear the steering shaft? and do you think they would work for 4wd?
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
theyre a log type header, I had to heat and rework them with a hammer until they cleared. truck is 4x4
Chris_97
thanks really helps me out
