96-01 V8 explorers did not have 4x4, they were either 2wd or all wheel drive. The transfer case is a single speed case, so there is nothing to shift. 2002 is the year the explorer had both a body style change as well as going to the modular 4.6. The 4.6 was not available in 01 as the motor is too wide for the body. If you plan to use the manual trans, I recommend the T5, like previously mentioned. Your truck doesn't have pats, but the 99-01 ECU does, and the ECU controls the pats.
96-97 no pats return style fuel system 3 wire cps
98 pats return style fuel system 2&3 wire cps (this year was a transition year to my knowledge)
99-01 pats returnless fuel system 2 wire cps
Both style ECU's can be reprogrammed to run either style fuel system, and also can have pats and auto trans deleted from the programming. This gives you some options on looking for a donor. The dash can be swapped, however you can keep your dash and just swap the dash harness. In 04 I believe ford changed the instrument cluster and the steering wheel. You can keep these, however repinning will be required of the instrument cluster. You can keep your steering column, just remove the auto shifter...
SVT
