302 Crate motor - need distributor
mccombs
I've got a 302 crate motor from ford (M-6007-X302 to be exact) and I need a distributor to match. I'm going carbureted with a Holley 570 Street Avenger.
I purchased a Proform 66969BK Vacuum Advance HEI Distributor with Steel Gear and Black Cap for Ford 221-302 from Amazon http://www.amazon.com/gp/product/B000N3345W
My PDF for my engine says "The distributor you select must have a steel distributor gear to be compatible with the hydraulic roller camshaft. Distributor gear M-12390-B for carbureted application or F for EFI application recommended." but the distributor information says "Technical Note: Gear not compatible with roller cams. If using roller cams, please contact the cam manufacturer for proper gear selection."
Will this work or did I pick the wrong distributor? What does everyone use?
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Follow the instructions for the crate motor. I would look at Summit and Jegs.
Sent from the garage of the never ending projects.
No members online now.
