Rearanger
- Feb 4, 2008
- 23
- Southeast USA
- Ford
If there's "too much exhaust flow" then that means the extra air entering the combustion chamber will be detected by the O2 A/F sensor and the MAF and the "leaner" burn will be adjusted by the computer. I haven't seen anyone here prove with a dyno/exhaust gas analyzer all this "lean" burn is actually happening. If in fact the factory has "leaned" these engines so much that the coolant cooled valve guides burn out before the valves, then we'd see 100's if not 1000's of Ranger valve guide replacements. Are there?ill tell you what the ford place here told my buddy on his 04 when he burned his valves out. the tune on the newer rangers (99 up) is super lean and any exhaust modifications will burn them out. it causes too much exhaust flow and the temperature in the chambers goes into the exhaust ports and cooks them.
