the 99 and so on engine, they did the changes back in 99 that are currently being used all the way up to 2010. its not that the heads cant handle the fuel system. its the fact that they tweaked the piss out of it and leaned it down so far to please the federal government and keep an older design. just cheaper on ford than going to a newer more efficient design that will easier pass emissions. most other vehicles they dropped a newer style engine in, why they didnt do so to the 3.0 in the ranger im not sure. i guess to make $$$ or the simple fact of if it aint broke dont fix it came around. i stand behind the 3.0 100% its an awesome engine dont get me wrong, but the 2 valve ohv arrangement isnt very efficient and has trouble passing emissions or producing peak power. thats why chevy went to smaller bores, the v8s went from 2 valve ohv to 3 valve sohc with variable valve timing in fords, the 4.0 ohv to an sohc 4.0 with better valve angles/chamber design, and the 2.3 lima to the 2.3 duratec. they simply breath better and can take the tune better. even your engine building manuals show for general purposes of calculating volumetric efficiency: ohv 2 valves 80% ve, 4 valve/multivalve 90% ve, and variable valve timing multivalve 95% ve. there is a lot of wasted fuel in the old 2 valve ohv engine like the 3.0, and to make emissions happy they had to lean it way down. this in turn lead to engine longevity problems, something that is inevitable from lean mixture. my question is why havent they redesigned the engine or use a different version of one that is the same displacement (older 3.0 taurus sho v6 or duratec 3.5 v6) for example.
