260,000 mile Ranger Maintenance
barranger
Any recommendations on maintenance I can do on my $65 2wd 5spd 3.0? I need to just do the bare minimum. If and when it needs a major repair it is gone. I have purchased a new air filter, battery and terminals so far. I may get some plugs and a fuel filter if it starts. starts.
Sent from my Nexus 5X using Tapatalk
17,940
SW Iowa
Yeah, I wouldn't go any deeper until you see what you got. Then maybe fluid changes. Might also check over the brake lines too.
Off topic but your trees are sure pretty. :icon_thumby:
Slammin Sam
4
Western Colorado
2.9
For 65 bucks, I think you can expect to spend some money. Judging by the tree sap on the body, I'd guess its been sitting for a while. Any idea how long?Usually a vehicle gets parked because something expensive broke. I looked at a lot of Bronco IIs that were parked for years because of a cracked head or the auto trans took a dump. Try to drain the gas and add fresh. Pull the pugs and squirt a little oil in each cylinder. With the plugs out, try to turn it over by hand. Then put in your new plugs and see if it will start. Keep us posted and good luck.
Doofy
7
Alaska
Shit Happens...Then You Die.
Such a sad case! Needs TLC Big Time. Of course, I feel the same way about animals. One step at a time and hopefully you can nurse her back to health.
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
it only being $65 means you can dump more money into it!!
ericbphoto
Overlander in development
16,686
Wellford, SC
6"
For $65, you can't go wrong. Nice truck.
BTW, be careful with Slammin Sam's advice
Pull the pugs
I don't think they will enjoy that. :D
MagicMexican
What did the previous owner say was the reason he parked it? I don't see any dents or major rust, I think if you got it to run, it could clean up nicely.
barranger
I was the one who parked it. The registration ran out.
barranger
Started right up
barranger
Oil dipstick shaft is rusted out
97RangerXLT
TRS 25th Anniversary
3,976
Fishers, IN
2"
31"
lol wash it. that will make it look decent again and will probably make you feel like getting it up and going.
How long did you park it for?
AJ
ericbphoto
16,686
Wellford, SC
6"
It started?
Yay!!!
Sent from my SM-G920V using Tapatalk
barranger
AJ
1-2 years. I would only use it like once a month.
barranger
Back in 2013 I asked the mechanic to change the transmission fluid while doing an oil change and he recommended not to due to the high mileage. Does that sound legit?
17,940
SW Iowa
When was it changed last?
