2016 Explorer 18's on 2011 Ranger 2wd
CharlyHunt
FORD
Hey everyone, I'm Charly. This is my first post here so please forgive me if I'm not doing this correctly.
I just bought a set of 4 18's factory wheels from a 16 explorer. I'm looking to install them on to my 2011 ranger 2wd. Just curious if anyone has done that already and what tire size I should go with. I'm looking to get something a little bigger than my factory tires but nothing that will rub. Thanks in advance!
fastpakr
2,841
Roanoke, VA
Are you sure the bolt pattern is the same?
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
bolt pattern should be the same, but the Explorers offset runs in the hi 30s.
I would at the least mount a rim to see if it clears on the backside before buying tires.
CharlyHunt
FORD
Thanks for the info. Ill make sure they fit without tires first. I got them for $150 last night so in the event they don't fit I shouldn't have too much trouble getting rid of them. Thanks again!
fastpakr
2,841
Roanoke, VA
Good to know. Not sure why I had in mind that they'd changed things up when the Ranger and Explorer diverged around '02.
17,926
SW Iowa
The diverge grew a lot bigger in '11. Ford seems pretty stuck on their 5x4.5" bolt pattern.
Everything is going to FWD like offsets though. :annoyed:
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
that allows for a wider suspension/frame to be used. then use the hi offset to pull the wheels back in to maintain the same track width.
17,926
SW Iowa
Still don’t care for the look. I like a little dish.
