2009 ranger head lamps
george44
My low beams went out on my 2009 ranger, but the high beams work. I changed the light switch and the fuses appear ok. Any ideas on what I should do?
Doofy
7
Alaska
Shit Happens...Then You Die.
Remove the bulbs and check them out. I've burnt out just the lowbeams before.
07nhbpsi
17
Monroe mi
Yep, had similar issue years ago..... both of my high beams went at the same time, ironic but still possible!!!!:icon_confused:
Doofy
7
Alaska
Should be a 9007 bulb. I would imagine there are 3 terminals, 1 pos for high beam, one pos for low beam and 1 for common ground. You could either ohm it out or test with a couple of jumper wires.
