2006 XLT 4x4 door sw dome lamp
imabrnconut
tobbacco rd, Ontario. Can
rubber side down!
so, here I am, at whit's end, and yes, I have tried to find older posts and/or comments on this, but nothing is helping me... door open indicators on in the dash, and interior light stays on. and yes, I have tested the wiring and switches in the front doors, because those are the indicators showing in the gauge cluster, so I know the door wiring from the door post connection, right into door and up to sw is ok and working. found out that the SJB is the wrong one in my truck, because my fogs light relay is not there, and there are NO connections in the SJB for it! must have been replaced at some time. so I found an SJB from a 2004 FX4 with fogs, and no change, tried a SJB from a 2008, and it caused all kinds of unwanted stuff, including no start. tried a non fog SJB from an '05, still nothing. since I cant seem to find a decent wiring diagram for the door wiring, from door sw to SJB...I'm asking here, does anyone have a decent wiring diagram to show the door sw circuits for my truck? And? is there a separate GEM module for the door sw's, or does it all pass through the SJB?? all the posts related to this, are for '2000 and older, which do not have the SJB fuse box in the passenger kick panel location. help?? if it helps, this truck was hit hard on the joint between the RH front and rear doors, had to replace the rocker up to first set of seat bolts, from front to back, both doors, and a mess of parts on the rear axle RH side...all fuses seem ok, relays are hard to test, but I think I will make a realy test bench just for this!
