I didn't put a proportioning valve in the vacuum booster is upgraded to a double diaphragm from a early 90's explorer that's my only other mod.I think it would stop better than say a TJ with 33's.
Some of the reasons I didn't go with a explorer axle is the cost by the time I get the 4.10 gearing in and it bought new brakes on it's going to be expensive.As I understand it's about 2" wider than my stock one and I'm close to needing mud flaps now to meet Cali law we've had write ups in the wall street journal how many cops are in my area and desperate to write tickets.
I would rather do this than change the rear by the time you move the spring pads to the top.Which has to be at the proper angle weld in some shock mounts.Plus I don't think my drive line would bolt up.I would have to take a torch and grinder to get rid of the existing hardware.I have the tools a and ability to do these things but I think it's a bigger job.I don't feel I put my rig through the abuse to need the big axle 8.8 If you put in a stroker small block or riding in big rock with big tires it's the only real choice.
I have heard you need either MC from a truck with ABS or a proportioning valve to get the brakes to work right with the Explorer rear disks.
The Explorer rear is actually closer to the same width as the front than the stock rear is provided a BII has the same front axle width as a Ranger (I think it is)
I shopped and found an axle that matched my current gearing (3.73), 4.10's were available too.
Match the angle of the new perches to the old axle and you are good to go.
But if you haven't been busting the 7.5 left and right... who cares
As for the gear swap if you already have a 4.10 in your truck just pull it all out. Keep track of your shims and put EXACTLY in the same place in the new axle. The gear swap I did on a different afternoon and still only took me half a day.
That will usually work, but you HAVE to have the proper tools and know how to use them and check it before you risk hosing a gearset.
Also an 8.8 axle is the same width as a 7.5
An Explorer axle is not. Ranger 7.5's and 28 spline 8.8's gained width in '93 too but were still not as wide as an Explorer axle. BII rear axles were wider than a 83-92 Ranger.
And the ranger flange is exactly the same bolt pattern as an explorer
Around 1990/91 (somewhere in there) and newer are. The older ones are much smaller and either require the flange removed and new holes drilled/tapped, a new flange with the smaller pattern or a new driveshaft with the corrosponding sized yokes. I drilled and tapped a new set of holes in mine.
http://www.therangerstation.com/tech_library/Axles.html
http://www.therangerstation.com/tech_library/Explorer8_8.html
