- Jan 3, 2009
- Reaction score
- 0
- Location
- lewisville, Tx
- Make / Model
- ford
- Engine Size
- 2.9
- Manual
well ive been having this poblem for about a week now.it started one day without waning and is intermittent. but EXTREMELY frustrating!
my 87bii 2.9l 4x4 started backfiring through the intake. and while you are drvng, and are on the accelerator, it randomly shuts out, not giving any gas or power. it does this in random gears.. some gears run great and the others are having the problem.
and other times it is really bad. backfiring constantly and my TOP speed is anywhere beween 15 and 35 mph.
oil change and tune up about 800 miles ago
i checked my injectors=good
changed fuel filter=good
i have propper fuel pressure
i checked and cleaned my distrubuter=all good
checked plugs/wires=good
and my air filter is brand new, and clean
everything is plugged in where it is supposed to be on the motor.
i checked my timing, it was a little off, i set it at 12 like the book says, and when i put the ground back on, it went to around 30. sounded good and ran like it used to. but on the way home, thr problem started again. an it has kept doing it.. threw some stp injector cleaner in to see if that helps any.
any one have any ideas? im getting more lost as time goes on.
thanks, kolton
thanks, kolton
