1998-2001 Propane Powered Ranger
hwew
I'd have a hose run into the bed that Tee's off the fuel line and keep a propane bottle from a bbq grilled in the truck for a backup in case you run empty on the road...
SVT
The 40 gallon fuel tank will be bolted in the bed behind the cab. I hear you about a reserve tank.
I only drive 200 miles a week. Hmmm, another tap for a BBQ grill.:icon_thumby:
Jraymer360
8
Belleville, MI
Good question, my understanding is this engine has a higher compression ratio than gasoline engines to compensate for the lower BTU gaseous fuels. I don't know if the propane carb is designed to have positive pressure. I think the engine will have a very short life the way it is set up.
http://www.edi-dist.com/ford_LRG_425_EFI.asp
says the comp ratio is 9.37:1
stock 2.5 from a ranger is 9.1:1 according to http://www.fordrangerforum.com/4-cylinder-tech/2051-2-0-2-3-2-5-specifications.html.
so not that much higher
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
What about splitting the 40 gallon into a 30/10 tank with a selector valve, if you run empty on the 30 all you need to do is flip a switch to your auxillary tank aka reserve tank...
SVT
Jraymer360
8
Belleville, MI
SVT
Or just do it like they do in aircraft wing tanks, leak proof the bed and get a metal tonneau cover and you will never run out.
cody93
42
Duluth GA
FORD
intresting little engine ya got there, ive heard of the industrial 2.5L, now i get to see one. im guessing it has a computer just for ignition, correct? best to mate it up to a 5 spd manual so you dont need 2 computers, also, get a different manifold, mid 90s rangers had tubular header style manifolds that are nice. and yea, deffinitly get a pre OBD-II truck, the more manual stuff, the better. as for tanks, id have 2, a hi capacity primary, and a 2nd BBQ axuilery tank incase you run out/go somewere else
scotts90ranger
4,482
Dayton Oregon
2.3 Turbo
looking at it again I don't see a vaporizer, just the R500Z, meaning it was either being ran on vapor propane (IE off of the vapor outlet of the tank) or natural gas, running an NJ vaporizer should be sufficient as they're rated for 100hp and are fairly cheap.
I build gaseous fuel systems at work, but for fork lifts and cranes and stuff and using GM engines, you service guys that work on Snorkel, Broderson, Versa Lift, Hoist, Royal, Tymco and Schwarze dual fuel or propane machines might have dealt with them at some point, who knows, might have talked to someone on the phone :). So, I'm not that familiar with the Ford industrial stuff but could fumble my way around... I've kinda wanted to play with a project like the one being proposed here, shouldn't be horribly difficult.
hwew
Hi Everyone,
Thanks for all the input. I have been away for a couple days and I need to set some time to get this project going. I will be writing again soon. Hopfully many of us will learn a thing or two about this conversion.
Thanks again,
Henry
hwew
Just found a mechanical throttle body that will mount on the CA-100 mixer. The cost is under $40.00. I hope to fire up the engine in a couple weeks to se how it runs.
tempforce
central texas
2.2
with your experience with the diesel rangers at 56-59 hp. you will feel great having 80+ hp, with a faster revving engine. 3.73 gears will give you plenty of on ramp power with decent mileage... lpg is around 105 octane, nat gas is 110 octane.
if you ever need to rebuild, buy parts to boost the compression up to 10.5:1 to increase power and mileage... you will still get less mile per.. than gasoline, but will be closer... being a industrial engine you won't want to rev the engine to high of a rpm. cable operated throttle and a large water heated vapor reducer is a must have....
if you live somewhere where you can install a propane tank on your property, get a tank with a filling pump. there still is a tax rebate available for the home fill station. just until the end of the year... the propane company may let you lease it....
as far as the emergency propane source, you can get fittings to fill your large tank from a smaller bottle... you will want to fill your vehicle tank while having the small bottle upside down so that you are transferring liquid, instead of gas/vapor. your transfer will be quicker...
i've been thinking of a mid 90's v8 ranger running liquid propane fuel injection. i found a company that makes injectors for ford mod engines, that use a factory computer and a wide band exhaust sensor. along with some propane specific safety items... the system does not use a pressure reducer... so no issue with cold weather line freeze ups... i do plan on bumping the compression to over 11:1 as the liquid propane cools the cylinder charge as it vaporizes. resolving some spark knock issues.
if your not running a turbo you can boost the compression... as your engine has had done....
keep us posted with your project.
cc
