^^^thanks broskie. Hoping to get things moving here again with good weather on its way.
Today I got over my rents n got it out. Ran well but eventually threw another alternator belt. Not sure the issue is but I am going to swap the pully to the stock one and see if that makes any difference. I had my tools on with me and some extra belts so a few turns of the wrench n was back on my way. I did use a $22 Napa belt vs the $6 AZ belts I've been using. Hoping it fixes it but we'll see.
I got to the junk yard and picked up my goodies minus the gauge cluster.
The drive shaft is much much lighter than my two pc, here's to oem ford upgrades
spindles look like hell but should clean up decent. I'll get the slotted n drilled rotors in up coming weeks. The calipers may or may not be seized so well see on that too.
I'll also be ordering new busings, ball joints, shocks and lowering kit.
Will also be looking for braided brake lines, any one have suggestion on those?
As for out back, I'll still be doing the explorer rear only probably swapping gears down my stock 3.08s or a new set of 3.33s. I'm looking to drop my highway cruise rpms a few and get some more top end speed. The 275 60 17 nittos are supposed to be 28 inches tall vs the 245 45 17s being only 26ish. That should help bring it close to where it was with the stock 235 75s.....hopefully. still researching tires since I'd like to change them out.
Pretty much it.
