1992 ford ranger 4x4 blinker problem!
danger_ranger_club
my blinkers and hazards only work when they want to and from what i see neither the blinker nor my tail light will work when i use the brake and blinker at the same time. im stumped..
3,614
Ok, let me try to break this down so that I'm sure we all understand:
Turn signals and hazards work intermittently.
Brake lights work
Tail lights work
If turn signal is on while brakes are applied none of it works.
Is that correct?
danger_ranger_club
yup. the blinkers and hazards work when they want to though. i was told a multifunction switch?
3,614
Multifuntion switch was my first thought as well. It's about the only place except the bulb that all of those circuits come together in one place.
danger_ranger_club
yeah and my bulbs are fine. i looked on the net for a switch and came up with nothing.
danger_ranger_club
and i also need a fuse box diagram. id like to rule out all the cheap options before i pull the trigger on a new switch
3,614
3,614
Yeah, but they only go bad about every 15 to 20 years.
Just hope that's it. That's an expensive part to be wrong about.
danger_ranger_club
is there any fuses or relays in the panel that could do that? it just doesnt make sense cause my turn signals WORK. just not with the lever so thats the only thing that it could be, right?
CJREX
8
N. GA.
2.3 EcoBoost
2.3
Check the wiring harness under the hood.
My Ranger did the same thing and the harness for the tail lights had fallen onto the exhaust manifold, melting the insulation.
The plastic wiring retainer had gotten brittle and broken, allowing the wires to fall.
