1990 Ranger 302
BowlEEac
South Surrey, BC
302
Thought id post a couple pictures of my truck.
1990 ext cab shorbox with djm drop beams and an inch cut from the front coils. Axle flip in the rear using toyota 8 inch with 4.30 gears, detroit locker and disc brake conversion.
96 5.0 HO shorblock assembled with arp fasteners. Edelbrock e street heads with PSP 1.7 roller rockers. Ford f303 cam. Edelbrock intake and quick fuel 650 double pumper carb. Homebuilt long tube headers with 1 5/8" primaries and 3" collectors.
Previous trans was a c4 with b&m transpac and a TCI 3800 stall convertor.
Current trans (almost done) M5ODR2 from a 97 f150. Centerforce dual friction clutch and hurst shifter.
XLTsplash
160
CA
2.3L
Great looking engine. Your Ranger looks great too. Other than being lowered it has a nice clean stock look. I bet it doesn't sound stock.
BowlEEac
South Surrey, BC
302
Thanks. There are a couple other give aways that would suggest it's not stock. The sound is definitely one of them :icon_thumby:
Bit of an update, 5 speed swap is done, Well driving at least. I still have a few things to tidy/finish up. It is so much better than my old c4. Made the truck much more fun to drive.:icon_welder:
BowlEEac
South Surrey, BC
302
I have the battery and a fuel cell mounted in the bed of the truck right now. Its cool and all, but kind of impractical. I Also have 3' dual exhaust that just exits straight out the back.
So what im thinking is put a high volume fuel pump in the stock tank and put the tank back in. Re route exhaust so it works with the tank, and tuck the pipes up in the back and dump them down to the pavement just before the rear bumper so they are hidden. Ill probably sink the battery into the floor of the bed aswell.
i like to drive this truck and among other reasons, id like the space in the bed back. The stock tank just seems more practical. what do you guys think?
XLTsplash
160
CA
2.3L
Using the stock tank sounds like a good idea, I will give you more room in the bed in case you need to haul something.
BowlEEac
South Surrey, BC
302
Everybody likes third gear burnouts
Always looking for the next "great" idea...
BowlEEac
South Surrey, BC
302
started to get my truck ready for summer season.
new wheels and tire, summit 55 series with OEM ford center cap emblems. 275/60/15 rear, 185/65/15 front.
drag springs and shocks installed in the front. started building a set of caltracs for the rear.
